Well things are progressing slowly on the 69 Stang, I'm waiting for parts. So while I do I'm working on other areas of the car. I'm going to go with a aluminum radiator which should add a ton of cooling. I've been looking at stock fan vs flex and electric. I can see a ton of advantages with electric fans but I also see that some of them pull a ton of current. 30 amps plus in some cases, I see some of the newer style fans that pull less on ebay that pull a lot less current but they have no CFM information on them. I also have a nice almost new large flex fan in the box that I purchased for the last build I was going to do I just never got around to installing it. I do seem to remember something about flex fans having an issue with coming apart into the radiator. Have any of you bought those 14 to 16 inch electric fans from ebay? I'm limited to 60 amps on my current alternator. using 50% of it to run a fan seems a bit much. So any info is greatly appreciated.
Thanks
Mark
Thanks
Mark
