I need some input for a 390 Ford Engine that was rebuilt but run with no oil pressure for a couple of minutes. Could any one estimate the amount of damage to repair it, I'm assuming that I will probably have to get another crank and bearings for it but I wonder if the cam bearings and cam shaft should be replaced, how about wrist pins Lifters etc, the lifters are hydraulic, would it be better to just install another rebuild or try to fix this one. When I heard the noise I shut it down but it was boiling the water out of the radiator. Would it be necessary to have the block and heads fluxed?. Any input into this is appreciated as I don't want to have to do it over.
