car runs 170 ish with electric fan running on city and rural streets.
at hiway speeds the car climbs up to 200 and rising, even with the electric fan running.
Ive installed a lower closeout panel
http://undercoverinnovations.com/in...s.com/index.php?main_page=index&cPath=30&zenid=b20fad2e7804311177b0ec9f819e7c5c
its supposed to help cooling but does the opposite on the hiway???
guess ill try with it removed.
car never overheated with the mechanical fan.
since installed a high output electric with 2800 cfm and full shroud
pic here.
185 degree temp switch.
radiator is a 2 core sized for BB chevy.
I did notice the inlet of the rad was squished a bit to allow welding to the side tank.
(might be a restriction)
upper hose is hard when at proper temp.
the shroud and fan covers the whole core area
pic:
I ran a direct mechanical 6 blade fan with factory shroud (always spinning) temps stayed 165 to 175 with the radiator im using now and upper closeout panel.
All i added was the above electric fan/ shroud with 185 degree temp switch and lower closeout panel.
I even uncorked the usually blocked rear water passages and ran hoses bypassing the thermostat to aid in cooling.
pic here.
pic:
