Are you for real !!! This is a Hot Rod site, and every Hot Rodder's always builds the darn engine first, then have to wait years before the build is done. That of-coarse means the engine just sits there patiently waiting for the fateful day. Just keep oil in the pan, so rust don't form. It would be great if people could turn the engine over every once and awhile to lubricate the cylinders, and allow other parts a oil bath, but it never happens. So, before you go to fire her up, make sure the valve cover come off, and the plugs out. Apply a liberal use of oil to the cam, valves, lifters and so fourth. Then kill the ignition and turn over the engine. With the plug's out, it should turn over pretty easy. Spray some lube into the cylinders first to help. You can run a quick compression check, once the battery is back to full charge, this would give you a very quick condition of many of the internal parts. If the engine can be primed, then by all means use a drill motor or pressurized supply to prime the engine, both before you turn it over and just prior to starting.
Have fresh fuel in the tank, and double check the oil level. Don't bother changing the oil if is has just been setting, but otherwise OK, you can change it latter after the engine has been run and been kept at temperature for some time. I would installl a new foil filter tho, they can disolve when letf in oil to long, so it's good and cheap insurance. Put it back together, and let it rip. If you don't have a electric fuel pump, yo will probably have to prime the system.
