flexplate wobble
2 reading
20K views 37 replies 6 participants last post by  BogiesAnnex1
Heres the story
We fired up my new motor and brought it up to 2200 rpms
Heard a wobble or knock like sound around the end of the break in 22 minutes
Sound is louder at lower rpms
We can really only see the wobble on the flexplate, torque converter at about 1300 or lower rpms
Engine has only 30 minutes on it max in my possession
The paperwork calls for a late 350 flexplate
So i got a new one meant for a 87 camaro 350
The harmonic balancer call for a non weighted one so i have a stock 350
What could be the problem?
Engine is a blueprint 355 flat tappet
Has this caused any serious issues?
The weight on the flexplate is facing torwards the motor and is on the dowel pin side of the crank.
Getting discouraged with this car stuff and i hope i dont need to pull this engine again
Update
Took off the flywheel and checked it out
Everything looked good and it didnt look cracked
I will get a video of it once i run it again
I just got everything back together and going to make sure everything is tight
My only guess would be i have the wrong flexplate??
Flexplate has a weight on the side of the dowel pin
Instructions call for a late 350 flexplate
Am i correct on this?
This post has been deleted
#15 ·
I did some research in the Summit catalog. You are right non weighted balancer and weighted flywheel. Still wondering if you have the right flywheel or if it is defective. The dowel indexes the flywheel to the proper location on the rear of the crankshaft. I take it you checked all that. And the flywheel is not reversed ? On backwards? (just putting it out there) Interested in seeing video.
#16 ·
Dumb question but it bears mentioning.
Are you using the correct process and torque specs to attach the flywheel? When we were kids, my brother bought a motor that the previous owner just went "around the clock" tightening the flexplate bolts to spec in one pass. This motor lasted about 1,000 miles before it grenaded. Also, the pete jackson geardrive and solid motormounts my brother insisted on both did a dandy job of covering up the problem until it blew.
Couldn't hear the noise or notice the vibration until it blew a window in the block and dented the oilpan on the highway at 2am LOL
Tap the flexplate with a mallet. it should ring like a bell. Move the mallet around, tapping firmly and slowly. If you find a dull sounding spot; you have a crack.
#17 ·
I have already taken out the flex plate and inspected it along with the back of the crank
Everything seems normal
I am torquing in a star pattern and can tell its torquing the flexplate bcause of the rings around the flexplate bolts are digging into the flexplate
I will loosen the converter and push it a little back for the video to show you guys
Everything looks good and idk what the problem could be
#22 ·
I guess I'm confused. Flex plates are not terribly stiff to start with so they can flex a little bit out toward the starter teeth but if you feel play somewhere near the crank flange than I'd say perhaps you have a rear main problem. How much end play does the crank have? Should be .005 to .007 or so.
#24 ·
Update
Pulled off my tc bolts and tried to out everything back on
I have 2 bolts in and i cant fit the 3rd
My wholes from the flexplate and tc do not line up now
It never did this to me before
Sounding like my flexplate is the problem?
Ive never had these bolts not line up
Also the starter is starting to make a weird noise when cranking so i can get to the bolts
#26 ·
Check the distance from center and to each other for the torque converter, there are not only errors but different diameters.
Be sure the flex plate matches the crankshaft flange the 2 piece rear seal is larger and different from the one piece seal. The one piece seal flex plate also carries a small external counter balance that the 2 piece seal fp does not except on the 400.
Remove the starter to look at its mountings of the block, if it got jammed by the flexplate that might have cracked the block ears where the starter bolts on. Usually it's the outboard that eats it.
#25 ·
No you shouldn't have problems but its life.
The bolt circle are not perfect bolt circles so you cannot put things back together the wrong way. The balance pad is there for a reason and so putting it back together with the balance pad indexed incorrectly would defeat the purpose. Youll just have to start one and see how the others lined up. If they don't turn the TC and try again. Then mark it for reference next time.
#33 ·
Hi, I read everything on u r post , I have never seen where u run a external flex plate an not an external balancer together, 350 are internal balanced, where as a 400 sbc is external balanced, you don't mix them up ...it can take out the bearings and the motor will vibrate, is there a part number on u r flex plate so u can look it up to see what it is for..it hope I helped some
