Ford Inertia Switch
11K views 15 replies 11 participants last post by  BogiesAnnex1
I'm considering installing an inertia switch (Ford F2AB-9341-AA) in my fuel pump circuit. Does anyone know what the current rating is for these switches? If they are only low current, I'll use a relay. If they can handle a few amps, I'll just wire it in series with the fuel pump. I just need to know how much current they are rated for, if anyone happens to know. Thanks.:confused:
#2 ·
Part shows to be for a 92 crown vic/marquis.
They used the inertia switch in the actual power feed to the pump, not with a relay. I have seen the inertia switch used to control the relay coil on mustangs, not sure why. But the part number would be different. Not sure if it would be a lighter set of contacts on the pony car part verses the one you have.
You should be fine to use it in the power feed to your pump.
It just seems like overkill to me. But what the heck, if you are running an electric pump anyway it's easy enough. There are other ways too, like having it running thru an oil pressure sensor so when the engine isn't running the fuel pump isn't either, there are cars made that solve the problem that way.
Just be sure to have that inertia switch in the same exact attitude as it was on the car you took it off of. :D
#16 ·
These switches became Federally mandated after EFI and high pressure electric fuel pumps became the norm to shut down the pump in a vehicle upset as two major conditions exist with these in that the engine may not shutdown and if a fuel line is ruptured with 40 to 60 psi behind it a lot of raw fuel quickly gets pumped out of the tank and into/onto the scene. Ford more than anybody should know about fuel fed fires after an upset or accident, every vehicle sold since EFI has one of these somewhere in some configuration.
Many racing sanctioning bodies have required these on vehicles permitted to run electric fuel pumps as well. The learning curve includes several people who survived the crash only to be burnt to death before they could get out. Even with mechanical fuel pumps these gadgets can be used to kill the ignition to ensure the engine is shut down following a crash.
Like packing heat, it only takes that oneth time to make it worthwhile to drag it around.
#13 ·
On my T-bucket, I had it wired to shut the MSD box off. The fuel pump was on an oil pressure switch. I read about a couple of accidents where T-buckets got squirrely (which they will do sometimes due to the short wheelbase/high power to weight) and jumped curbs or medians. It was just my way to prevent total loss of control.
T's can be a real handful. You always have to be aware of whether the road has water or sand or dirt on it. They can swap ends with you quick. Mine drove like a stock car most of the time, but I did spin it once right after I first started driving it. I learned to pay closer attention to road conditions after that.
#15 ·
On my F-150, it is on the drivers side under the dash on the firewall. Some F-150's are in the center under the dash.
When I put the 5.0 HO out of an LSC in my 65 P/U, I went ahead and mounted the inertia switch on the passengers side kick panel as that is where the wires reached. And yes they go between the relay and the pump, so they handle the full output. I have only seen 1 fail ever, so they are pretty dependable. I think that it's a good safety feature.
Sent from my moto x4 using Tapatalk
