Hello group...... I have a nagging front brake issue that has me, and everyone I know stumped.
The car :
1970 Monte Carlo, big block (originally small block)
I switched from small block to big block, and thus had to change my booster from factory size to a dual diaphragm 7 inch booster/master cylinder setup for 68-72 A-bodies. Inch and 1/8 bore size which is stock size. Also installed a bandit vacuum pump. All parts came from LEEDS BRAKES. Driving the car I had to almost stand on the brake pedal to get the car to stop, even at 10mph. So..... At this point I didnt know if it was the front or back brakes, so I bought a brake line pressure tester from LEEDS. Rear brakes are supposed to have bout 600 psi. I got over 500 so Im calling that good. In the front theres supposed to be 1200, I have 500 also. Im calling that wrong. So to remove the distribution block (down on the frame) from the equation as the faulty part, I made a brake line going directly from the front brake side of the master cylinder directly to the pressure gauge itself. Same thing about 500 psi. I had sent the MC and booster back to LEEDS to be tested, they said they were fine and sent them back to me. So today they had me check the brake pedal ratio which turned out to be about 3.75. For power brakes, the brake pedal ration is not to exceed 4:1, so Im calling that good as well. Im at a loss. I only drive this car in the summers, and didnt drive it at all last summer at all because of this issue, so its starting to get to me. Any help or ideas of what else I could check is greatly appreciated.
Thanks guys......
The car :
Thanks guys......
