American,
the reason your one leg rear doesn't grab at launch is due to the stock truck weight distribution (around 65% front/35% rear sitting level??)
your not lifting the front suspension quick enough (!!!) and/or far enough to transfer enough weight to the rear at launch...
(that's what putting some blocks in the bed would actually do,,,help the front end lift)
preface,,, I'm assuming your front suspension and steering are all original parts (which are getting tired)...
my cheap/easy/effective way/choice to cure weight transfer and balance the tires grab is:
add just one or two "load leveler" coil spring rubbers (or the twist-in kind) to the driver side front coil spring,,,that put's a minor lift pre-load on that spring,,,counters the motor TQ twist,, and restores the spring to original height (and rating?),,,just jack up the truck to install and costs <$10?...
{the D side front spring has lived a hard life,,,every time you have driven away from a stop sign/light all the motor torque was transfered into that spring}
if you carefully measure left and right sides from the floor to a same point on both the fenders,,,darn common to find the D side is sitting a 1/2 to 3/4" lower than the P side (spring rubber added cures that)...
second step is "tune" the front sway bar...
release just both end links bolts and confirm the sway bar is free to pivot so the whole front can/does lift instantly,,next to no pivot resistance,,,grease the pivot bushings if needed ...
(at a drag strip guys often set the end links bolts to way way loose to help transfer weight quicker but for street safety you DO want that bar to function)
the shapes and sizes of the bars and oem end links rubbers varies to much to give explicit instructions so just for the "idea":
usually (80%? of the time),,,a slightly taller end link stack (1/2"?) on the D side helps by countering the motor twist TQ so the bar can/does respond quicker (partly cause your D side motor mount is worn),,,test to see what just adding some fender washers to the D side link does for launch traction/burn out pattern...
"fair chance" due to your stiff frame,,, you will have bite and both tires will break loose with just those two easy to do changes!!!
LOL,,, how in the world do I explain the following clearly and briefly????
first,,, measure the "stock" installed/compressed end link height from the bar end to the A frame,,,just fairly close is good enough and write down the measurement for future reference...
the end link rubber donuts come in a huge variety of shapes/demensions/rubber durometers (=how elastic)/materials and they are inexpensive...
you can mix and match different donuts on a link,,,say have 2 rubber and 2 urathane on a link so it still rides smooth over pot holes but the bar can/will respond abit quicker on hard launch....
heck,,, you can bench grind a taller-softer rubber donut and/or cut the tube spacer by a bit to accommodate a taller one used to compress abit quicker at launch...
"because" when you have found a installed new donuts combo you really like for ride and launch the last thing to check is that the bar is at reasonably close to the original position based on the new compressed link height measurement (within + - 1/2" should be plenty close) ....
additional potential benefit from playing with the donuts is all around more responsive steering/cornering....
(oem parts choice is to accomodate both on and off road on a pick up as a example)...
summary:
LOL,,,
with about $20? worth of parts you can spend a whole Sat trying different combos and have a excuse for doing test burn outs at a SAFE location without even breaking a sweat doing the changes...
for others reading this thread tuning/tweeking the front suspension on a older unibody car can really help...
the (simple) rear gears change/gain math:
motor flywheel TQ x tranny ratio x rear ratio = total TQ acceleration force applied to the tires (versus car weight=power/weight ratio)...
illustration:
300ft/lbs motor x 3.0 low gear x stock 3.08 rear gears = 2772 ft/lbs of tire twisting force applied to the tires...
300 ft/lbs motor x 3.0 low gear x say "3.73" rear gears = 3357 ft/lbs of twisting force!!!!
edit add:
here's a link to "all" the Wallace racing calculators to save...
including one for determining cruise rpms from mph and gears ratio and tire diameter by just plugging in values...
http://www.wallaceracing.com/Calculators.htm
http://www.wallaceracing.com/gear-speed.php
