The starter turns the engine at about 200 rpm to start.
That means the dizzy turns at about 100 rpms
That comes down to 1.66 turns per second
You said it wont spark when turned 1 rev per 2 seconds.
Doesn't seem to be enough of a difference to me to cause an issue, but it does seem according to the math that there is.
If it wont spark at a slow RPM it will make starting the engine hard.
2 things that come to mind are that
1: The pickup coil is a PM generator. The faster they are excited or turned, the more voltage is produced. This MAY be the trouble. If the coil is not up to par, or the magnet is cracked, it could be a problem as far as producing a clean voltage spike strong enough to fire the module.
2: The other thing is a circuit in the module that is called "active dwell"
The ignition coil is never grounded with the Ignition on and the engine off, UNTIL the engine is turning over (spinning). This is done to keep the coil from overheating and burning out in case the ignition is left on.
The active dwell keeps the coil on time sufficient to charge the coil to provide ample discharge voltage without staying on too long at slow RPMs which would in turn build excessive heat in the coil.
It is likely the module needs to "see" a certain amount of voltage spikes in a given amount of time to "Wake up " the module, to activate the ground on off pulse to the coil. Kinda like priming a pump.
Part one is all fact. Part 2 is mostly fact but I can only speculate on the precise operation of the "active dwell" circuit and its functionality. One of Motorola's little secrets (Original designer)
Other than the fact that the active dwell does control the on off time of the coil primary to prevent a meltdown, how it initializes upon startup is a guess for me. An educated one, but a guess just the same.
You can check the voltage output of the pickup coil with a voltmeter ,it will give a good enough reading to give you a POV reading (Peak output voltage) .
IIRC it takes about 1.25 volts at minimum to fire the module.
Were you having trouble with the engine it was in?
