My question is I am putting a Demon 6 Pack on Vortec heads. I need 1 1/4" length bolt to attach intake but have 1 1/2 length grade 8's. If i use 4 grade 8 washers to get to 1 1/4 " length and then torque to 11 ft pounds, will the washers be ok or will washers cause incorrect torque? GM has a bolt just for the vortec head but looking for alternative with bolts I have. Also, GM says 11 ft lbs which does not seem like enough. I wonder if this torque spec is for use with composite intake on TFI and if you use aluminum intake should it be more ft lbs? I also am using the GM intake gasket which does not suggest using sealant around coolant inlets. Thanks in advance for your input.
