H.E.I Question
951 views 4 replies 4 participants last post by  BogiesAnnex1
Will a H.E.I from a sbc fit and work in a 96-98 chevy vortec truck engine?I'm trying to set one up with a quadrajet.
Yes, the only issue is drive gear compatibility with the factory roller cam. GM sells a Melonized steel gear, it's OEM on engines with factoy rollers, the P/N is 10456413, should cost from 30 to 40 dollars. This has much better wearing qualities than either bronze or composite gears and will not tear up the cam's gear.
