Harmonic balancer torque spec
12K views 12 replies 8 participants last post by  ericnova72
Hey guys quick question, having a difficult time getting to 130 ftlb on the harmonic balancers bolt. Holding the belt by hand with everything i've got i was able to get to 117 / 130 ftlb, close enough right? OEM bolt with loctite.
I'v got the factory dust shield over the TC and didn't feel like lifting the car just to lock the flexplate haha. I will if i have to though.
#4 ·
Hopefully this isn't a SBC or BBC. That is too much if it is.
A Nailhead is 200-220 ft/lbs. It requires holding the crank at the other end via pry bar between the flexplate or flywheel bolts. And it requires a 1/2" impact to remove, or one big cheater pipe on a breaker bar.
#6 ·
Man that's wild as h ell
"200-310 ft. lbs."
Seeing it cannot believe what I'm reading.
I would check around some, maybe contact a source like a Fluidampr That's all the make ..
The Original Fluidampr
Maybe ever ARP
If it were me I'd talk to some pros, just to verify. SNAP is not a good sound anyone want to hear..
LOL
Been wrong before, but that's a big number on that bolt...
But then again the lugs nuts on my truck are 140 ftlbs
Pep
Oldsmobile Torque Specs
and
Oldsmobile Full Size 1970-88 V-8
Not sure why the olds engines call for such a high spec
#10 ·
Dang!! My airplane only requires 20 ft lbs on the bolts that hold the prop on. They're 3/8" bolts fine thread.
If they were coarse thread, the torque would be less.
But then again, I've found things that should be tourqued to some astronomical figure, just barely tightened. Tapered axle hub bolts come to mind. They should be liberally greased, tightened 'till it squeaks, then turned another round. But, Folks seem to think that it has a cotter pin, and should be snugged like a front wheel bearing. :rolleyes:
#11 ·
The factory spec is 60 ft pounds with engine oiled threads.
The ARP bolt is 80 foot pounds with their magic thread lubricant.
Don't forget to put the proper lubricant for whatever the bolt you're using under the washer and the bolt head as well or the torque ready will be reached before the proper stretch and that leads to the bolt coming loose.
#12 ·
Hey bogie thanks for the info, can you show me where you got that?? Only reason i ask, is because i have not been able to find a source that shows less than 130 FTLB for my 79' olds 403, thanks.
I save every webpage i find now to a hard drive because information on these engines is becoming increasingly limited sadly.
