Looking for some input & suggestions:
I have an HEI and the timming retards at 3K rpm and continues to retard with rpm.
Thought at first the vac advance can may be bad & all testing has been with no vacuum advance at this point.
Using a Snap-on digital dial back timming light.
I've tried 2 GM HEI's and 1 Chinese HEI....same results
I put an volt meter to the battery as well as the power wire to the HEI while running and it is getting full voltage.
I've changed a few plug wires in attempt to see if I had some bad wires & will test more Saturday.
Thanks
Thanks
