So I'm starting a SBC 350 build, but intake manifolds and cylinder heads are starting to throw me for a loop; constantly having to check between different ones.
For starters: The ONLY thing that I am saving out of the original engine is the block itself. Not the heads, not the crank, NOTHING. Just the 350 cid engine block. The block came out of a 1989 Chevrolet 1500 pickup 2WD.
The heads and intake manifold that I want are Edelbrock products on summit racing. The Heads are "Edelbrock Performer RPM Cylinder Heads 60899" and Intake Manifold is "Edelbrock Performer RPM Air-Gap Intake Manifolds 7501". Both of these say they only go up to 1986. Now I've done *SOME* research; apparently the only real difference between a 1986 BARE-block and my 1989 BARE-block is the main seal. The blocks are completely identical, except the 1986 would have the 2-piece, and my 1989 would obviously have the 1-piece.
If I got the Edelbrock heads and bolted them to the block, everything should be fine, right? Because the top of the block where the heads mated up is completely identical, correct? The intake manifold should just go onto the heads.
Thanks in advance to any/all who help.
