Guys, trying to get a few things fine tuned. Right now, I'm running a Holley 4160, 600cfm with electric choke and vacuum secondaries.
My Setup
86 Silverado 4x4
SBC 355ci
700r4
3.42 rear gears
I'm running 12' initial advance with a total of 36 all in. I'm showing really close 16hg on the vacuum gauge at idle. The primary jets are 65s and the power valve is a 65 and according to the paperwork that came with it I have the plain secondary diaphragm spring.
Here's the deal, if I'm light on the throttle it runs normal in any gear. If I punch it to the floor from a dead stop it does fine in first gear but starts to bog in second and unless i back out of it. If I punch it in 2nd or 3rd I get a bog, but If I give it medium throttle I'm fine. My thought is that the secondaries are coming in to soon. By the way I have my air/fuel screws backed out 1.25 turns where i found the greatest stable vacuum reading.
Any thoughts? Also is there a way to stop the secondaries from opening all together so I could test my theory? Also, if I get a spring kit should I use a heavier spring? Oh, and is there a chance that these symptoms could be fixed with an adjustment to the accelerator pump?
My Setup
86 Silverado 4x4
SBC 355ci
700r4
3.42 rear gears
