Honing and rings question
2.8K views 13 replies 7 participants last post by  imacarfan2
I pulled apart a shortblock I have and plan on doing a re-ring/re-bearing to it. I didn't plan on taking it completely apart, but a couple of the bearings were iffy, so I figure I'll throw some new rings in while it's apart. The crank looks good as do the cylinder walls and there's no ridge at the top of the cylinders, either, so I think a quick hone job with a bottle hone, then the new rings and bearings and it should be good to go. This is going to be a mild street engine that won't see over 6000 RPM, so this should work fine.
Since I've never used a hone of any type before, my questions are:
Has anyone here ever used a bottle hone (or dingleberry hone, flex hone, etc.)? I'm asking because I'm trying to find out what grit to use. I see 120, 180, 240, 320, and 400. I'm pretty much honing only to break the glaze so the new rings will seat. It looks like the 120 and 180 are good for cast rings and the others are for Moly rings. Anyone have any suggestions on which grit to use? I'm thinking of using regular cast rings, but would go with Moly if people think it would be a better choice. I figured cast would be fine in this application, but a friend says I should go Moly. Thoughts?
Again, this engine will be more of a street cruiser, but might see the track once in a while on a street night. I'll be building up a bigger motor later on, so this is just to get me buy for a season or so. If it blows up or implodes or anything, not a huge loss.
Thanks for any thoughts or comments!
#2 ·
hone
Remember I own an automotive machine shop so I am going to lean on the safe side….
That being said, you really can’t tell the condition of a bore just by looking for a ridge at the top. They can be out of round, tapered, oversized etc… You really should at the minimum check for those conditions before you do anything.
IMO there is no substitute for a Job done on equipment that can make the bore round and straight.
If and only If the bores meet the above you can use a flex-hone on them IMO.
Have to agree with K-Star ^^^ Using a hone or BRM deal is okay so long as you understand bore finish. Some guys swear by a light rub with just paper and no hone on re-ring. You really need to understand what it is the hone is doing for you, or more specifically, your ring to bore interface. There is plenty of information/debate pertaining to bore finish and rings used too.
#6 ·
Thanks for all the info so far. I understand that a ball hone is basically going to remove the glaze produced by the old rings and add some crosshatching so the new rings will have a better chance of sealing. That's pretty much all I'm looking for. I know it's not removing any material (well, probably nothing of any significance).
Here's the deal with the engine. It's an AMC 390 I got it in a parts buy. It looked pretty clean (the surface rust is from sitting in my garage), so I took it to the machine shop to have it checked out. He noticed the fixed cracks and two sleeved cylinders (see pics below) and also noticed two freeze plugs missing, so he said I should try to find another block (not real easy being an AMC 390, but I was successful). Since I have basically nothing into it, I was going to just install some new freeze plugs, put the motor together, run it and see how it goes. I decided to check out the bearings and noticed some of them had some copper "lines" in them, so I figured I'd throw some bearings in while it was apart. That's when I decided to pull the pistons and throw in some new rings as well. The cylinders are standard, but the crank is already .030/.030, although it looks to be very clean with no issues. I'm now thinking I may pick up a bore gauge and see what shape the cylinders are in. If OK, I could just re-ring it. I might take it back to the machine shop and see if they'll check it out to see what it needs, but I'm trying to do this cheap as I already have a bunch of other engine projects going and sucking up my money.
K-star- Since you're "in the biz", what are you're thoughts on this?
Thanks again for all the comments and keep 'em coming!
Oh, one last thing. When I pulled the pistons, I looked for the mark that shows if they're aiming forward. The only thing I found was on one side of the piston where the pin is, on both sides of the pin is a big F. I take it this is for FRONT or FORWARD. Problem is, there was no rhyme or reason to which way the pistons were facing! Some had the F toward the front, while others were facing the back of the block. AMC uses offset rods, so I can't just turn the rod and pistons that are facing the wrong way around. ARGH!!! I did note, though, that all the stampings on the big end of the rods (to keep the right cap with the right rod) were all on the same side, so I'm assuming it's just the pistons were hung on the rods incorrectly. Clearly not a high dollar rebuild. :rolleyes:
This being the case, I might end up having to have the block honed or bored and buy some new pistons anyway. I reeeeally didn't want to have to do this, but it seems it might be the case.
This is a dumb question, I'm sure, but what issues would arise from running the pistons the wrong direction?
Lastly, in the bottom picture above, you'll note the bolt hole looks a little rusty. Yes, I'm going to chase all the threads as well as remove any surface rust and thoroughly clean all the parts (block, rods and pistons, crank, etc.). I'm not THAT stoopid! :D
#12 ·
block
Again, what i would do and what you can "get away with" are worlds apart.
The very first thing i would do with that block is hot tank it and mag every square inch of it..
Sleeves,welded deck, missing freeze plugs.....all adds up to a block that was frozen one time, and probably hard...
Keith
#13 ·
After seeing those pics I would do exacly what K-star says, or find a different block. I hate to see you try the cheap way out to save a buck just to find out it will cost you more time and money in the end.. :sweat:
I have found out th ehard way that the easiest way is never the right way.
#14 ·
After weighing all my options, I've decided to do as suggested. I'm going to take the block to the machine shop and have it checked out. For a couple hundred bucks, I can have the piece of mind knowing whether it's OK or not.
Thanks again for all the comments and suggestions. :thumbup:
