Hot engine start issue
1.4K views 7 replies 4 participants last post by  Joe23
I have a custom 49 chevy PU with a chevy 383 HEI ignition. Engine starts fine and runs great. Turn off and after 5 minutes of a hot engine and try to start I get no spark to plugs. I replaced the coil, ignition module, wires, cap, rotor. Still no spark. Finally ut in new distributed, still have same problem. I'm lost!! Any help would be appreciated
#2 ·
Do you have 12 volts going to the distributor?
Is the distributor grounded to the block? The clamp is the ground path so make sure that the clamp ring is clean (no paint).
How are you testing for spark?
Run a jumper direct from the battery to the distributor to eliminate the wiring and ignition sw.
vicrod
possible frayed/broken wire from the ing switch, could be engine bay side or the firewall connectior or cabin area....... cabin side ..... make sure no one has tapped into that wire to run something else or it has a solid connection to the switch terminal........ firewall connector...... corrosion or broken connection at the bulkhead connector....... engine bay ..... wire broken/frayed or it could be brittle from lying on the engine etc.....
Good luck
#8 ·
Joe23
Could it be in the timing or ground straps for battery. The battery sits in the bed of the truck. I've set the timing at between 10-12 BTDC. When cold starts fine and runs smooth. Again this is a 49 custom Chevy with a 383 cu in engine. This starting issue is driving me crazy! Recap of what's been done.
New fuel pump. Re-route of fuel lines away from heat. New distributer. New battery. All new guts to distributed. I am getting spark when this no start on hot engine occurs.?????
