Hi I have a few small chev motors at my disposal (will probably be using a 307 or 305) and a set of world 305 heads. I've just brought a very reasonably priced solid cam for it (stuff isn't any where near as cheap here as America) but the person I got it off only had 3 specs for it and I don't know what lash clearance to set it up at?
Here is his brief description:
Newly reground cam , 255 deg @ .050 , .337" lift , 108 . Was in a 350 i brought but i'm running hyd lifters . No good to me .
Does any one know what clearance I should use? That is the only info I have on cam so far. I have vee blocks and DTI but no degree wheel yet. Is there a method used to calculate the clearance or do I have to get cam shop to check it? There is no useful info stamped on cam, some have been ground off (I presume because it's been reground?).
Any help would be much appreciated.
Edit: also the 307 I'm currently running has a new edelbrock performer RPM airgap manifold and edelbrock 600 vacuum secondary carb with headers and HEI. Trans currently has B&M nitrous holeshot 2300-2500 converter and will be getting full performance overhaul. I might look at putting a higher stall in it too (comp cams 286h is what I wanted to put in it after having a play with Camquest, but I might have a go with this one since I have it).
I presume I'll have to upgrade my carb for this cam too? any recommendations? I was thinking of a mighty demon 650. Please keep in mind I'm not rich either
