i tryed to run it from the + part of my battiry to a switch, to one end of the spark plug, and the same with the -.
When you hooked the plugs and switch up, did you need to do anything to your stock spark system to cut it off temporarily to get the motor to just run on momentum?Nailheadforty said:Haven't done a flame thrower since high school days.
Factory Option from BMW:RedSled said:Sort of the same subject; I did some work in South Africa, and they install propane flame throwers as a theft deterent!! Not from the tailpipes though...... from the rocker panels.... holeee They are serious about security!!.![]()
I seen that on the TV. The driver has a little button on the floor that he can just step on hard and flames shoot out from under te car on the sides. I think they said some guy invented it cause there were a lot of road thefts that just stopped you on the highway and jacked your car.RedSled said:Sort of the same subject; I did some work in South Africa, and they install propane flame throwers as a theft deterent!! Not from the tailpipes though...... from the rocker panels.... holeee They are serious about security!!.![]()
