Do you guys think that there is an ideal lobe seppearation angle for a motor and if so, would it be based on the rod ratio?
You may enjoy reading some of the wisdom of Ron Iskenderian, son of the famous "Camfather", Ed Iskenderian. Read through these Tech Tips and enjoy....Dirty Biker said:Do you guys think that there is an ideal lobe seppearation angle for a motor and if so, would it be based on the rod ratio?
turbolover said:are you after power or mileage? Two very different goals.
Also, rod ratio will not have much affect considering your intake and exhaust are not tuned, nor are you running good heads, carb, etc. All those things have a FAR more significant impact than rod ratio.
If you ask people at a party if they think rod ratio has an effect on ideal lobe sepparation angle even I wold look at you funny!Dirty Biker said:Well I ask this after running a chain calculation of cams thru this dyno sim and using the stock 283 I have here as the mule. Trying to learn about this has been a wonderful adventure for me, I really appreciate having a place to ask this stuff to people that think about these things too. If you ask somebody at a party if they think of a cam they just kinda look at you funny. I tried it couple times last weekend. They start talking to you about this and that, yadah yadda and then there's a break in conversation and they look at you like the smiles and the nods are no longer adequate responses, and so you say "So, do you think a longer rod ratio kinda wants a cam with a tighter lobe separation angle than a short rod combo?" Then they realize that I have been trying to figure out how to make that into an equation the whole time I was smiling and nodding at them. I hope I do get closer to figuring it out someday.
Here is the point, I am trying to see the trends in the chain calcs of the stock 283 on the sim. It seems to do better with tighter lobe separation angle but less duration. So, short duration but tight cam angle. Kinda backwards as to what comes on a modern engine, that being a wide lsa and a long duration. I just wondered if you guys thought it was just the 1.9:1 rod ratio of the 283 that caused that. If rod ratio plays a role in cam selection, then it could be thought that there might also be a theoretical ideal lsa for your inherent geometry, whatever that may be.
My theory is that long rod motors do better with tight lobe angle and short rod motors do better with wider lsa. I read that wider lsa gives better gas mileage, and that led me to thinking about all this to try and understand it. Wider lsa and long duration seems like it would be almost the same thing as narrow lsa and short duration, but it is interesting how the two do not test the same on the same engine on the dyno sim. Thanks
Johan Lokander said:If you ask people at a party if they think rod ratio has an effect on ideal lobe separation angle even I wold look at you funny!![]()
I think stroke can have far more effect on what LCA an engine will have than rod ratio. I haven't ever considered the rod ratios effect on LCA before, but maybe it has some effect...
What this really boils down to is wanting a custom cam for a stock 283- not really much need for it IMO, but if you want one just call up your favorite cam company and ask for one- the good ones will probably tell you to just buy a shelf stock cam as it is cheaper and will serve its purpose quite well.Dirty Biker said:Thanks for the reply,
power or mileage? I believe they can go hand in hand don't you?
Not in a NA sbc
If you consider that the manifold and heads installed stock have characteristics and flow numbers that can be used to aproximate as an in tune condition, sure it isn't cross ram but it still a column of air moving and should behave in a predictable manner that would allow me to attempt to optimize what I have to work with here. The smaller runners of the stock manifold and small valves can work in my favor to create velocity at lower rpm and get a small amount of tune pressure despite my small displacement. I do want better heads and manifold someday though, don't get me wrong here. Just trying to use what I have for now, and if it costs 200 bones (for the custom cam)to find out if a hair brained scheme can really work or not then I consider it a bargain.
I don't know why you would think those components are tuned for anything, they're not, they were cast to serve a basic purpose- deliver air and fuel to the cylinder, it does that, but not in a precise manner.
so power and mileage go hand in hand? I say yes because a tuned engine is an efficient engine and and an efficient engine gets good gas mileage.
It can if you have a lot of time and money to go into development- a good example would be the new LS series, they have decent power and decent fuel consumption- it took 40 years of development for GM to do it.
Unless you are drag racing.
I've seen a stock air cooled VW bug drag race- it ran a 23.1 in the 1/4... Power is power regardless of where its made
I am not trying to change rod ratio of my engine here at this time, this post is really about the lsa and how it affects an engine. I was just speculating that maybe the rod ratio played a key role in the cam design style whether it be tight lobe but short duration or long duration but wide lsa, and how the rod ratio should then go into consideration when selecting a cam. So 1.45 rod ratio people with all that great intake velocity and vacuum can get more power from a wide lobe cam with long duration and 283 or 327 guys over on the other end need a tighter lobe angle and real short duration to help make strong low end power. Lemme know if I am on the right track here
For this engine a relatively mild LSA like 112Âş will be a good start- that has more to do with cylinder heads, exhaust, intake, carb, stroke, and other things than rod ratio- you really REALLY overestimate the impact of rod length.
What do you think affects piston travel more .500" stroke or .500" rod length?Dirty Biker said:a motor with more stroke would most likely also have a shorter rod ratio tho, rod ratio affects how fast the piston leaves tdc so a shorter rod makes a stronger intake pulse signal and so can benefit from a cam with more duration and is less diluted by wider lsa right?
no
This is just what I am noticing so far
I would rather have the half inch more stroke!turbolover said:What do you think affects piston travel more .500" stroke or .500" rod length?
I am not sure I understand your question there. The position of the piston in the bore of any motor at a given crank angle depends on the rod ratio. This boils down to me wanting a custom cam for a stock motor is true, but I think it will help and will only cost an extra hundred bucks to find out. If it does no better than a stock cam then I will have learned alot for cheap.turbolover said:What do you think affects piston travel more .500" stroke or .500" rod length?
see bold text.Dirty Biker said:I am not sure I understand your question there. The position of the piston in the bore of any motor at a given crank angle depends on the rod ratio.
No it doesn't, plot the piston position with 3 different strokes, and 3 differet rod lengths and see what it looks like, 9 excel charts that I think will revolutionize your thinking on rod ratios
The thing is what cam tho? The position of the cam in relationship to the piston is affected by the lobe angle, so I want to optimize the peak lift to be where the piston is creating the most air velocity is all right? The position the piston is in while moving in the bore when it is accelerating at the highest rate should be where the cam is wide open then right? On a long rod motor the piston accelerates from bdc faster than a short rod motor so it needs different exhaust valve timing because it has improved exhaust velocity, on a short rod motor it is when the piston is leaving tdc it accelerates away from tdc faster so a cam that starts opening the intake valve earlier than what was ideal on the long r/r would be better. So a cam that works really good on a 350 might not be best for a 283. It seems like most of these off the shelf cams are made with the 350 383 and 400 in mind given there popularity.
Johan Lokander said:You ar rigt that a cam that work well in a 350" our larger engine dont neceserly are the best cam for a 283".I dont think it has much to do whit rod ratio tho.Maby a littel, but the cubic and stroke have alot more to do whit it.
If you build a 350" with 5.7" rod and one with the exakt same specs but with 6" rod i dont think they will ned mutch diffrent cams...
I think you over think rod ratio, and I understand why peopel look at you funny att partysDirty Biker said:A 283 with stock rods has much higher rod ratio than a 350 even with 6 inch rods though. Not just a little bit but alot different. If a 350 could be made that had the same rod ratio as the 283 it would need 6.7 inch rods. I argue then that this much difference has to be taken into consideration in cam selection. It is a known fact that narrow lsa angles help create strong intake pulses. That helps the long rod motor to make more velocity at low rpm because the long rod motor doesn't make intake velocity as easily as the short rod.
Dirty Biker said:It is a known fact that narrow lsa angles help create strong intake pulses.
yes the rod ratio is what determines the position of the piston. A short rod motor at 45 degrees past tdc and a long rod motor at 45 atdc will have the piston in a different place in the bore. The short rod motor will have the piston down in the bore a little bit more at the same crank angle on the way down. Might only be a little bit but I think it is enough to affect the tune and warrant buying a custom cam. And get the 4/7 swap for the heck of it. I wonder if the 4/7 swap makes it scavenge better on dual exhaust setups where there is no crossover equalizer pipe installed.turbolover said:see bold text
turbolover said:The stroke has more impact than the rod.
I've tried to lead the horse to water but it appears it wants to die of thirst.
I am using 36 inch long headers 1.5 inches in diameter. My stroke is not going to change. I like the 283, I am just trying to use it to learn a little bit about cams.turbolover said:The stroke has a greater effect on piston speed.
With a stock exhaust manifold you won't want a narrow lsa. A shelf cam would work well on your STOCK engine.
