ok here it goes....
i have a freshly rebuilt 454 that i put in my 81 firebird.
bored .030 flat top pistons so around 8.5:1 comp. with 049 heads, heads are pirty much stock with only a spring upgrade to fit my edelbrock performer RPM cam.
i have the timing set at about 34 deg. at about 2000, seemed to be were she liked it best. initial is about 18. now it runs awesome under 2000 but anything after that it backfires alot and sometimes will backfire through the carb. and will only sometimes backfire at around 1500, and this is only when i am just putting around. it runs very smooth when i am getting on it but when i let off is when it starts to do it. i was having some bog issues and was told to drill out my shooters a little bigger, but i think that i may have drilled them too big now. it doesnt have the response like it used to. i drilled then tested and continued process and was fine but now that i drilled it again out a little more this started happening. but it always had the exhaust backfire above 2500 RPM. my mind is boggled........
