I Just rebuild my 555 BBC, and it smoke from one side, i take the plugs out and found that cylinder 2 spark plug was with oil and it smokes trough the spark plug hole. It's smokes a little on idle, but when i press throttle it smokes a lot, valve stem seals are new, pistons are new, rings are new, and all gasket are new also, also the block was bored and i check the measures and they are correct.
Pistons are Mahle forged that comes with rings.
gaskets are fel-pro
Can the intake gasket cause this?, remember that it's smoke hardly under throttle
pd: i also change spark plug cable, spark plug and injector and the problem persist.
Regards
gaskets are fel-pro
Regards
