which would be better for a truck ladder bars or a four link?
aosborn said:Triangulated four link for the street...
Casperdude898 said:anyone got any good plans they would share to make a kit or anyone kno anywhere that sells a good kit for not to expensive
I see you have 2 threads going.Casperdude898 said:its a 85 silverado with probably around 450 horse mostly street driven but like to take it to the track so im thinking triangulated 4 link is gonna be my best bet
Four links, four bars, all the same. You could as well call it a four bar linkage. Don't get hung up on terminology. Maybe the OP had parallel in mind, or maybe triangulated, but lecturing him on irrelevant (and incorrect) terminology doesn't answer the question.NEW INTERIORS said:They don't make a Triangulated four link,It's called Triangulated four bar.some people sell them, calling it a Triangulated four link,But it's is suppose to be called Triangulated four bar...The good thing about it,You don't have to run a panhard bar.The bad part is you can't dial it in like a four link set up. :thumbup:
Semi-correct. Ladder bars are for straight line racing (drags). On the street over uneven terrain they will try to twist your axle like a torsion bar, and something may eventually break.sunsetdart said:if it's going to be mostly street, go with ladder bars. They are much easier to adjust than a 4 link. 4 links are mainly for racing due to sooo many different adjustments for different track conditions.
user151 said:Four links, four bars, all the same. You could as well call it a four bar linkage. Don't get hung up on terminology. Maybe the OP had parallel in mind, or maybe triangulated, but lecturing him on irrelevant (and incorrect) terminology doesn't answer the question.
Not correct. A 4 link and 4 bar are NOT the same. Way more adjustment with a 4 link.
Wrong!!!! There not the same.Don't care what you have read,They are different. :nono: :nono: :nono:user151 said:Four links, four bars, all the same. You could as well call it a four bar linkage. Don't get hung up on terminology. Maybe the OP had parallel in mind, or maybe triangulated, but lecturing him on irrelevant (and incorrect) terminology doesn't answer the question.
Your correct!!!!!! :thumbup:57halfton said:On a 4 bar system the bars are normally parallel like on street rods and do nothing to improve traction ???????????
And on a four link system the bars are not parallel and have many adjustment holes so the instant center can be adjusted to improve traction ?????
Thats the way I understood them to work.
Gene
user151 said:OK guys, I guess you mean that a link has an adjustment on each end, and a bar doesn't.
So in the interest of learning your definitions... does it matter if the link end is a Heim or a bushing?
I see some kits have a bushing welded to one end of the bar, and a threaded bushing on the other end - is that a link or a bar?
Tom
