Trans removal time depends on your skill level, tools and if you have a way to get the vehicle up in the air to physically work on it. Driveshaft removal, shift linkage removal, cooler lines, modulator vacuum line, Unbolt the torque converter from the flexplate, push the converter back into the trans, Then a proper trans jack, crossmember removal and six trans bell housing to engine bolts. I have a lift so it takes me about 35 minutes taking my time. Transmissions are heavy so safety counts. Trucks take longer because of the transfer case.
Something I forgot in my previous reply is also to check the front pump gasket and also the outer seal. I always replace with a new gasket and new seal. it is a square cut seal. I always use Vasailine on the seal and a small amount on the circumference of the pump when installing. Never use the pump bolts to pull the pump into place, You will most likely strip out the threads on one or more bolts. These are small 5/16 bolts and will easily pull the threads out of the case!
I have two 5/16 bolts that are about 3 inches long with the head cut off and A slot cut in the cut off end. The slot is for a screwdriver. I use these as alignment pins when putting the front pump in place. A rubber hammer or plastic dead blow hammer with small taps usually seats the pump in the case. I then remove the homemade alignment pins and then install the bolts. *Please don't use a metal hammer to tap the pump into place. You will crack or distort the pump.
Hope this helps.
