Find a governed semi going 60 to 70 MPH in the slow lane. Sit back from it's bumper 100 to 120 feet matching the speed. If it exits find another.
This will let you cruise for most of the trip behind the semi with a good amount of following distance in front of you while keeping the engine happy. Depending on the ride the difference between 65 and 75 may be noticeable.
The soccer moms are going to come up on your butt going 90. But most will get the idea real quick that your taking a long trip. The few that get in between you and the semi will give you like 20 feet before moving in front of you then roughly a second later move back out of that slow lane as they run up on that governed semi's butt. Most people will simply pass you at 90 quickly followed by the semi.
Now when there are no semi's I try to kick it up to 75+ just to avoid the person coming up to you at 90 then sitting along side holding up the others behind them just to check out the ride. At 75+ they can sit behind you and talk/think about "the one they had" before eventually passing or exiting.
Good chance you can find a semi within 10 minutes at 75+ to then sit back behind at 60-70mph.
This is basically how I drive most of my classic rides or any of my square bodies on the highway. It is more relaxing and safer then being "in the pack" of people going 90 while others are holding them up(in the fast lane) at 70 who soon get cut off(as they should be if the slow lane is completely open). The ones that go 70 in the fast lane are to scared or stupid to know how people should merge into that slow lane.
I drove semi for 7 years with a governed semi in the slow lane. Very few exceptions where I felt it was needed to move over for a 4 wheeler that could not go faster or slower to merge how they should.
When driving in general and especially when pulling a trailer I am in that slow lane going a constant speed. They figure it out after a few seconds and often get in front of me before going 5-15mph faster or drop back before going 5-15mph faster.
When driving a classic do the same thing. Just hold your ground and stay out of that fast lane.
I like to use an app called Waze when driving. It lets me know of things like vehicles on the shoulder(those I move over if possible), police ahead(move over also), object in roadway(tires or roadkill), and railroad tracks ahead(to save your rims/tires/oil pan/ground effects). I been using this thing for years and while it can be inaccurate in the final location of residences at times it is based on a community that gives live updates in real time. It's like Telsla's current network of all there cars(and robots) talking to each other without the them telling on that one person in the group that wants to go 50mph over the speed limit briefly.
If that guy going 50mph over the speed limit causes a crash then I will have fellow waze'ers ahead of me telling me "item in roadway" "lane is blocked" along with "traffic reported ahead" possibly "police ahead" and if it is far enough ahead the route can be recalculated around the mess. If not I can give more following distance to avoid the 1/2 bumper in the right lane. If by the time I come up on it the stuff has been cleared then fellow wazer's will update that also.
As far as a tool kit(keep this in the ride at all time (cheap tools only)
-Cheap socket kit with a 5.5, 7, 8, 10, 11, 12, 13, 1/2, 9/16, 14 sockets and a ratchet of course with two 3" extensions.
-Wrenches with the above measurements with a adjustable and a pair of pliers.
-Wrap 10 feet of 16 gauge wire in a ziplock. Wrap of 10 feet of 10 gauge wire in a ziplock.
-Wire cutter/strippers and circuit tester with a lightbulb not LED.
-Cheap universal screwdriver kit that has flathead, philips, and torqx bits
Sure you can add to this
-Spare rotor
-Spare blade fuses and relays
-Hand warmers and a blanket(the blanket can keep you warm while also be used for laying/kneeling down on without being covered in mud etc).
-A gallon of Distilled water filled 3/4 the way up. For adding to coolant or if need be drinking while waiting on a tow truck. At 3/4 it has room to freeze and not burst the container.
-Can of fix a flat(as a last resort)
Before taking a long trip pull the tires off the car. Using the in car tire kit. This does a few things. It lets you know the kit actually still works and lets you see if you have a lug nut that is impossible to remove kind of deal. Better to find out in the garage where you have more powerful tools and time for pentrating fluid to work then when your on the side of the road with cars flying past at 70+ in heavy rain.
I perfer to upgrade those scissor jacks with a bottle jack(if it will fit under) or a cheap 1.5-2 ton mini floor jack(fits under anything). I still use the scissior jack as a 2nd safety measure. But its alot easier to lift things with hydraulics.
Having two gives you reduncy and doing this before hand lets you see that you actually have that lug wrench in the car and that the spare is not flat.
Of course I still carry a dedicated thing of fix a flat and throw a 12 volt tire inflater/jump starter in the ride just in case that spare turns out to be flat(I never forget to check things before hand).
Oh and after checking that everything works by pulling the tires off and then back on then retightening the lugs after a short 10 mile drive make sure to put that tire changing kit back into the car. Has never happened to me more then twice. Thats where the can of fix of flat comes in or the stuff for waiting on a tow truck.
As far as a tune up. Before doing these I like to wipe down the side of the block and transmission(i often paint these silver) and then take a few short drives to see if I find any runs. Wiping down the block keeps you cleaner when working on it while letting you see that a leak is coming from the valve cover and not the rear main etc.
Once your sure you have no leaks(or at least know where they are) you can do basic inspections.
Plug wire inspection, spark plug inspection, cap/rotor inspection, points inspection, hoses inspection, belts inspection, air cleaner inspection, fluid level check, lights check, wipers/washer check, heater check, and most importantly radio check. If anything looks questionable or bad then fix it.
On the coolant front I do this check and top off fluids including filling the overflow to the cold level.
Get in the cold ride and without warming it up head down a country road(no one around) getting up to 80mph as fast as you can driving a bit mean while getting there and hold it there for about 10 seconds before cruising down to 70 for about 5 seconds and then pull over and sit with the thing idling for 30 seconds. The thing should have gotten to full operating temp by now and it should be sitting somewhere around 190-205F(with a 195F thermostat). After idling for 30 seconds drive mean once again back up to 80mph before dropping to 55 and cruise back to where you had the thing parked.
Shut it off and let it sit for 5 minutes. Lisen for any bubbling sounds. After 5 minutes start the thing and it should start somewhat easily. Now with your foot on the brake and the thing in drive sit in the thing for 15 minutes just idling watching that temp gauge. After 15 minutes if it has not went over 210 your good. Shut the thing off and slide some cardboard under the radiatior leaving that there till it cools off then check the level once cold.
What you simulated is having a sit down lunch then getting back onto the highway before coming across a traffic jam. You also simulated pulling into a gas station and after filling up you were able to easily start the thing.
Now that you tested these in a somewhat controlled situation when you encounter them you will know your cooling system will be up to the task.
Your coolant should swing between 190 and 210 during these test. If it is below 190 then you have a lower thermostat or none at all and it should be replaced with a 195F thermostat. Hotter coolant temps produce more power and the fluids are designed to work with coolant around 200F.
This is long enough. Stop reading and get to work.
