Lots of bolts to prime
1 reading
3.5K views 15 replies 8 participants last post by  deadbodyman
Recently, I completely disassembled and blasted a frame for a P/U along with all the brackets and suspension parts. Now its time to reassemble everything and I was going to prime all the bolts first but decided put it together first and use a brush on the bolts to apply the epoxy so I don't tear the primer off the bolts during assembly. Regardless of how I apply the primer ,I was wondering if I should etch the bolts first in Ospho (theres a lot of new grade 8's) or just put it all together and brush it on the heads and nuts as they are...my question is will the epoxy stick well to the new bolts without etching first?
I'm using SPI epoxy and it says self etching on the can. A lot of these bolts will be taken back out at some point in the future and I don't want the primer flaking off...Has anybody been through this?
In the SPI torture test recently posted the guy primed unsanded steel and it stuck well I was thinking about giving it a shot ,I've got all the nuts and bolts sitting in a coffee can filled with wax & grease remover waiting for me to get started I'm thinking once they are dry, brushing it on will be fine.
#4 ·
many of the bolts are new,The problem is I worry about the primer sticking to that shiny yellowish surface of the grade 8 bolts ..Theres too many to blast ,acid also takes too long ,and I already know they'll chip if primed before installation no matter what I do. that's why I'm going to install them first THEN prime with a brush regardless of how they are prepped. I was kinda hoping they wouldn't need any prep at all, other than soaking in W&G ...
I guess new nuts and bolts would be ok if they came in semi gloss black...I know a lot of bolt kits come in black but if I cant buy them in bulk that's out. bolt kits are expensive.
What about those viberating tumblers? That might be another option if they work and I could just load it and walk away. Anybody use they with good success
#6 · (Edited)
I just got back from HF and they have the drum type and a vibrating cleaner for 50.00 plus the abrasive. I think I'll give it a try ,it seems like the way to go with the lest amount of labor .......went to tractor supply for bolts and nuts but everything I needed was empty. Theres a big bolt warehouse in town ,i'll see about some of those black coated bolts on monday
#11 ·
tumbler may take a loooong time to do anything
i have one from eastwood, i use for cleaning/polishing small parts.
it doesnt do much to steel, i can imagine it would help a lot.
i think the sand blaster would be much better/faster
#8 ·
After seeing that video on the SPI epoxy, I would stick them through holes on a box, etch them a bit with a sand blaster and put a bit of epoxy on them.
#9 ·
That's the way I've always done it too. I'm looking for another less labor intensive way to do them.I decided to go ahead and get the tumbler to clean the nuts and bolts ,if it works all I have to do is load it and walk away ,that's perfect for the cleaning. After they are clean I'll install them then brush on some primer, I think this will work great for a couple reasons, like its pretty cold out so the epoxy wont cure very fast and I need to get it together asap installing them first then brushing on some primer sounds like he way to go. If anyones ever had to blast a few hundred nuts ,bolts and washers in a cabinet I think you'd like the idea of throwing into a drum ,turning it on and walking away ,come back and they are done...I'll drop 50.00 bucks to find out .I'll come back tonight and show how well this worked or didn't work.
#10 ·
I've tried many things and in the end nothing works. I used to sandblast my bolts and then epoxy them, but after a few turns with a wrench it eventually gets chipped off and they start to look like crap, though I will say the epoxy holds up a lot better than the base coat does. Usually the bc/cc comes off easily and then you can see the gray epoxy beneath. I have to be very delicate and careful when I wrench. Now I've just resorted to dumping them in a phosphoric acid bath with the mastercoat metal prep that has the phosphoric acid and zinc phosphate and the bolts have stayed nice looking for a year and counting so far. They come out looking parkerized.
For blasting or painting I take 2x4 scraps, drill a bunch of 1/2" holes in them and stick the bolts down in the holes. Then I just go over it a few times with the gun at some different angles until everything looks like it's been covered pretty well. Same goes for blasting. But that drum idea sounds like it'd work pretty easily.
Needless to say this will be the only project where I ever paint the bolts.
#14 ·
This gives me an idea..... I usually grab about 3-4 bolts put a towel between them and a large vice, hold them tight before hitting them with a wire wheel. Im going to try to drill a hole slightly smaller than the thread size on the bolt, thread the bolt in and wire wheel them while they are lodged into the wood... Ever tried that?
#12 ·
mike, i dont think the tumbler will clean them much. more for polishing but depends on media. i would still clean them well before painting. if there is any oil residue from mfg it will contaminate your media quick .
#13 ·
I have used a "Vinyl wash" etching primer from S-W that is very thin, very, very thin, so it hangs onto things like bolts more. The wrench won't chip it off like thicker materials. I experimented with it, even though it says to top coat only with another primer, I once painted over it because I wanted the film to be very thin. After doing a few abuse tests I found it to work just fine and applied it to the hubs of a vintage Harley so the paint would be very thin and not chip off at the spokes. It worked like a charm and saw the bike for years with no failure.
Products: E2G973 - VINYL ETCH PRIMER
#16 ·
I forgot about this thread. Update...
Well, I ended up buying mostly all new grade 8's and putting it all together and taking it all apart about three times THEN when I was sure it wouldn't need to come apart again I just carefully brushed on the epoxy I couldn't see spending a bunch of time on bolts.it seems to be holding up pretty well and you really have to look close to see any brush marks no body but me knows the difference. I did the frame in SPI black epoxy also, I really like the OEM look....I gotta tell ya that SPI is some pretty tough stuff ,I wasn't able to be as careful as I should have been ,doing it alone , but the epoxy handled the rubbing and scuffing like a champ with no touch up.:thumbup:
