For a few months I have been discussing the Fiat engine..... Time to start fine tuning the thoughts
There will be no plastic or ECM. This is a carb build
There may be an ignition driver for spark unless I can fit the cam driven dizzy to fit with the radiator
Short block will be a 5.3 LS4.
The block is a FWD LS variant with the 60 degree V6 flywheel housing mount. The sleeves are ultra-thin, so max overbore is 0.020" to a final bore of 3.800". Unlike the other LS 5.3 variants, this block can NOT be bored to 3.9"
Initially the short block will be stock until I blow it up.
Bearings will be swapped
The heads will be stock 243 castings.... And will be hand ported by me. Yes, CNC porting may be better..... But nowhere near as cathartic.
Springs are still TBD, however will be a bit on the heavy side to keep the lifters tight against the lines up to 7500
Cam will be a Comp XER281 or a TSP MS3.
The lifters will be Johnson LS7 or the "caddy" racing lifters from GM
Instead of the stock lifter trays, I want to copy the Jesel dog bone retainers as I do not want plastic bits in the motor
The rockers are yet to be determined. Leaning towards stock rockers and lash caps because the lift will be over 0.600". However may go with 1.72:1 rollers from TSP
The water pump must be remote mounted. Right now looking at the Mezier electric pump, the alternative is a belt driven Mezier
No power steering.
AC compressor will be mounted under the head on one side, the alternator on the other. However the recent rain in Florida has me looking at mounting the alternator up high in the valley
Flywheel is currently the flex plate and a quarter master 2-disc clutch. Under 17# total
No power steering.
