I have a bbc and it has eagle forged crank and h beam rods with srp forged Pistons in it with arp head studs and a iron headed rec port heads with Vic jr intake and 850 demon carb.im running a 150 shot now and want to no what the max is on my set up
Max is depending on your current compression and fuel type. You will get a variety of answers. What is your goal? Additional 300HP? 500HP? 1000HP? Then it gets into fuel delivery, timing, plugs, piston design and so on. N2O can be fun and addictive - but can be costly depending on the set up.
I now prefer to run boost as a power adder. Power is always there when needed, no bottles to fill and change, no fuel changes, less changing of plugs, no bottle blanket/heater, and etc. etc. etc.
Depends on the current compression ratio and ring type....but the crank and rods should be good for 400-500 HP without a problem.
Also depends on the block ...2 or 4 bolt main??, 2 bolt I wouldn't go over 325 HP or so. Same with Plasma Moly rings, use Hellfire rings or similar if you want to shoot over 325-350 HP regularly.
How much are you wanting to shoot??
Fuel type/octane will be important also, what are you going to be using??
Completely stock cast crank, cast piston 2-bolt 454 with a cam change will handle 200HP with no problem, your current 150 hp on the forged crank and H-beams with forged pistons isn't even felt by the parts.
Related Threads
Hot Rod Forum
posts
2.2M
members
183K
Since
2001
