Status
Not open for further replies.
Melling M55 done after 5000rpm?
34K views 51 replies 17 participants last post by  jeepers creepers
I've read lot of things on the forum about the causes of oil pressure drop, oil level, windage tray, oil pick up height and its related brazing to the pumo body can afflict pressure.
Mine is very good, about 70 when cold and over 35 at idle at operating temperature, the problem pop out when engine turns close to 5000 rpm, the gauge pointer has a superfast vibration from around 5 to 35 PSI.
Cavitation?
Looking for the cause on the web i've seen that some oil pump has problem over 5000rpm or so, any experience with them?
i'll tear down oil pan to check pick up height first (honestly i want to see bearings too) then braze the pick up or make a bracket for it.
#3 ·
car isn't running yet, driveshafts are missing, PSI at 3000 rpm are surely more than 30, i guess something around 55, but i will check them out for sure, idle pressure is way more from 10 PSI.
#4 · (Edited)
if me i wouldnt get excited until you actually get her on the road and driving, one thing is if your just sitting and revving theres no load and no real world effects on the engine. get it on the road drive it easily for a bit till your comfortable with how it runs and start getting into the throttle little bit at a time and closely monitor your pressure and temperature.. every engine i build gets the pickup tack welded. (be sure to remove the cotter pin and spring from pump the heat from welding has been known to distort the spring).how many rpm is the motor intended to run? and what are your driving habits? for sb's i like to use the m55hv pump with purple spring(70psi),is that what you have?also if the problem persists after you have it on the road,try another(mechanical) gauge.i hope that helps ease your mind, i know how it can be time/money= edgy.. for the most part sb's are very reliable and forgiving if well maintained and not abused...
thank you for the reply, i'm with you about real life so i have to put my junk on the road before, but... what will happen if engine will run approx 5000 for seconds? i'm concern about that, revving it up is relatively safe, i guess it wouldn't the same thing when the load is on it.
Pump M55 is supposed to be the stock replacement for the SB chevy and i would stay far away from any high volume or pressure pump with stock clearance engine like mine, i think it's gonna be just too much load on cam and distributor gears.
My pump works pretty good until 5000 rpm and i can't understand the why, befoe to get crazy with this and that i want to know if anybody has experienced issue like mine, i wan't to make sure if is just a Melling pump problem before.
#8 ·
i understand your concern, so for now go find yourself a mechanical gauge and see what you get. as far as the hv thing goes, you'll always get a mixed bag of people and suggestions when it comes to hv pumps, but as long as clearances are within tolerance then i will always use a hv pump on a street motor.if you did the cam breakin you should change your oil, i would use a straight viscosity unless its real cold where you are, try 30 wt.
#9 ·
definately, i want to try with a mechanical gauge and see for any difference, thank you.
#10 ·
Cavitation?
This is a mechanical gauge? Because if it's electrical, look for a bad connection.
The first thing I always look on ANY gauge when I get an abnormal, 'screwy' reading is the sender and the gauge. Check the pressure using another gauge, and check the connections, especially if you're using plastic tubing.
Cavitation IS what comes to mind, though. This is most often caused by the pickup being too close to the bottom of the pan rather than the PU being too high. And as you've suspected, the pump can pull air past a pressed on tube, although this isn't common especially if a new PU was pressed on correctly. But if the old PU was reused, or the job wasn't done just so, you can still pull air.
Use a good oil filter, too. The Fram filters have been reported to have problems associated w/pressure loss.
Not at all likely to be the problem, but still worth mentioning is the filter mount bypass. I like to block it off so the filter receives all the oil, but caution must be used when the oil is cold, and to keep an eye on the pressure- it will continue to drop as the filter becomes more and more restricted.
#12 ·
Cavitation?
It's not a for sure thing to say when the engine is running with no load on it. Engines make some pretty strange vibrations on the crank and when these are not damped by a damper on the front of the crank and either a flywheel/clutch assembly or torque converter on the other, these shakes can be transmitted into the cam via the timing set. These could excite the distributor gear to shake about in its clearance which would transfer the shake to the oil pump. But frankly I'd be surprised that the average oil pressure gauge would have time to respond.
I'd expect that this is either the bypass valve chattering or the pump gears doing the same, or the inlet pipe is shaking and drawing air on and off. This also could be too much or too little clearance of the pick-up to the bottom of the pan.
Chevy pump gear chatter is a common problem often fixed by milling a groove in the cover plate from the discharge side to the opposite side of the gear. The cause of this is the 7 tooth gear of the pump is just too close to a harmonic of the engine's firing order; plus the bypass returns to the inlet side of the pump so the pumps operating frequency which is imprinted on the oil outflow is fed back in to the inlet when the pressure bypass is operating. This can really shake the daylights out of the gears.
The Chevy inlet being pressed into the pump cover leaves a lot to be desired, I don't like friction fits, I've never seen them last. If this is leaking air the pump input will become unstable a condition that will worsen with RPM. The usual solutions are to braze the inlet to the cover, another thing I love is getting cast iron that hot, and using a brace to carry the structural loads of the pick up off the connection point.
Other things about the pickup is that it needs to have the anti-vortex cover with screen at the intake side. The needs to be from 3/16ths to 3/8ths inch off the bottom of the pan or 4.8 to 9.5 mm.
#13 ·
great responses guys, they're so much apprecciated.
i'd love to do the grove on the pump cover and try to avoid cavitation, i have to braze the pick up wich was new but i want to make sure no air will pass through the pipe.
#15 ·
SSedan64 said:
This link shows the Pump Mods>> http://www.chevytech.info/2c63.html
Many Builders recommend just changing the oil Filter after Cam breakin to retain the ZDDP additives in the oil for a longer period.
great link, thank you, pump is down ready for the mods, problem is to make to vertical groove on the gear bore, i haven't the right tool for that, but grooves on the bottom are easier to do, do you think i can make just them? any con?
thank you.
#16 ·
Cavitation?
Competition Products in oshkosh wi. sells an oil pump pickup bracket .Nice bracket .LARRY :) :)
#17 ·
A regular oil pump pressure relief valve is set to release at 55-60 psi and unless there is a gauge issue what you are seeing is the relief spring surging without a load on the engine causing your gauge to fluctuate rapidly.
Don't worry about it, its normal.
Save
#18 ·
thank you.
To see much improvement I'd think you would need both ends done. A small Die Grinder/Rotary Tool with a cone shape Carbide or Diamond Burr will work if you can find one.
Examples>> http://www.harborfreight.com/power-tools/rotary-tools.html
#21 ·
SSedan64 said:
Wow! That looks and sounds like cavitation at the Pump's Pickup? :confused: You can hear the load on the engine change when the Pr. drops.
i guess so, nevertheless as somebody told me in this thread engine has no load on so it's better to try the car on the road before.
i saw the "oil pump mods tutorial" , very interesting but i don't want to mess up and end with a piece of junk so i'm thinking about a new and different oil pump, stock pressure and volume is a must.
#23 ·
302 Z28 said:
If your still relying on the electric pressure gage your chasing ghosts. Find a mechanical gage and get an honest pressure reading.
Vince
You're right, the oil pressure sender is probably on the worst spot ever,i just need to make a hard breath and do that.. mechanical gauge is on the shelf.
#24 ·
retainer
A pump screen assembly retainer or brace is available from Summit and Jegs. It is retainer part #23620 for a 3/4" inlet tube. The M55 tube such as you have has a 5/8" diameter inlet but it will still fit if welded to the tube. Since my oil pan is 9-1/4" deep, the pick up assembly is more subject to vibration damage than a shorter tube assembly. I used the #23620 retainer after cutting and shortening the pick up tube 1/2" in order to fit a Melling 10552 HV/std pressure pump. I tried to fit Milodon and Moroso screen assemblies that were equipped with braces but I could never get the desired 1/2" oil pan bottom clearance with any of those pick ups. A vortex under the screen and severe cavatation will result if the pick up screen is less the 3/8" from the botton of the oil pan.
I used the special Melling tool and drove the inlet tube into the pump housing then bolted the #23620 brace to the tube, welded it and tossed the supplied retainer bolt in the trash. I bolted the bracket to the oil pump bottom plate with red Loctite. Severe vibration can weaken the oil pump pick up tube, especially if it is a long pick up assembly for a deep oil pan. The #23620 pick up retainer dampens vibration that can work harden the tube at the pump housing connection, even if the pick up tube has been brazed to the cast iron pump housing.
#25 ·
BB Chevy pump
Cavitation is a common problem with SB Chevy oil pumps unless you use one that is designed to reduce cavitation. Those type oil pumps also reduce oil pressure below 1200 RPM and are recommended for racing applications only. A good solution would be to install a stock BB Chevrolet oil pump. They have larger diameter spur gears with more teeth and run smoother with 10% higher volume than a SB chevy oil pump. Unfortuantely, the inlet tube is clocked differently in the pump housing and the baffles in the oil pan may need trimming to get a BB Chevy pump to fit. I tried to fit a stock BB Chevy pump but the inlet tube hit the back of my 4.3L V6 4X4 oil pan. The BB Chevy pump will fit most SB Chevy V8 oil pans.
If you trial fit and can use a BB Chevy oil pump on a SB Chevy V8 engine, you will need to get a Moroso oil pump drive shaft that is designed for that conversion. That shaft is shorter than a SB Chevy drive shaft to allow for the slightly longer BB Chevy gear shaft.
Status
You have insufficient privileges to reply here.
