I building a mild Ford 302 to drop into my 62 falcon 4 door. Let me know what you think and any guesses as to how much power it will make?
Build specs are:
Stock 78 block
Stock crank
Stock rods
Speed pro positions with a 1.615 compression height 5cc valve reliefs
Ford e7 heads with the pedestal to stud conversion heads have been milled 12 thousandth
Com cams xe 250 cam very mild cam.
Harland Sharp roller rockers with 1.6 ratio
Edelbrock performer 289 intake
Edelbrock 500cfm 4bbl carb.
Head man shortly headers(not much room for anything else)
I have bough a cam degree kit and will most likely end up with different pushrods. I will also be running Ford racing plug wires and good plugs. Will also be running pertronix I and flame thrower I coil. So what do you all think? Im hoping that this will make great power for my little falcon. Thanks Anthony
Build specs are:
Stock 78 block
Stock crank
Stock rods
