Ok. here is my new problem. I cut out the floor of my 37 Ford Tudor. The owner before me welded a new floor over the half rusted old floor. I am waiting for the new floor to come, so I have been working on getting the doors set. Been looking at the body for quite some time and noticed that there is a reverse crease on both sides of the roof in the same spot right next to that I think "B" pillar. I talked to the owner before me and asked him if he did something different about moving the body around. He told me that from time to time he did move the body around with a fork lift. There were no doors on the car, so he used a tow strap around the bottom and hooked to it at the top and picked it up and moved it. One time he was in a hurry and just put the forks threw the door and lifted it that way.
The gap in the door opening isn't bad on the passengers side. The drivers side really needs the help. The gap in the front looks good. It also looks pretty good at the top. The rear is really tight. I cut a piece of 2x4 about 3/4"longer than the opening is now, and started pounding it into place. The door is starting to fit better.. I would like to know how the guys who channeled bodys mounted them back onto the stock frames?? I thought that maybe if I get a couple of 2x4's and put one down low on that post, and put another in the middle, and maybe a third near the top. I could always pound in shims to push the post to where it should be. Then weld in the new floor.. Not sure if that would do much good either though?? I also could give it a hit in the lowest, mid, and up higher to try and keep it there. I was talking to one guy. He said to talk with some of the guys who channeled body's and remounted them onto the stock frames.. They might have the answer.. Thanks.. Al
