MSD Ultimate HEI Upgrade Kits
2.3K views 2 replies 3 participants last post by  Rustydawg
I'm considering one of the MSD Ultimate HEI Upgrade kits for my GM HEI ignition. Does anyone have any experience with these? Is this just a parts swap or does it necessitate readjusting the timing, etc?
#3 ·
The MSD HEI module is a little tougher to get in and out of the ditributor body, I found it necessary to remove the distributor from the engine to mount it properly. In that respect you will have to re-set the timing when you re-install it. I wouldn't expect it to change anything else though.
I went with the matching MSD coil and was impressed with the increased spark output - especially at higher RPM.
