Hi, This isn't a real hot rod problem but my hot rod is taking a back seat untill it is fixed. Which frustrates me to no end. My 98 Windstar van 3.8 has a problem loosing power. Especially when warm but not limited to this. It goes along fine then you can feel it loosing power. It will downshift as you squeeze the throttle and the rpm picks up as it goes into 3rd from od. You can buttom it out of OD ok but it is still loosing power. I changed fuel filter and there was some improvement for a couple days. Now that it has gotten warmer it happens almost right away. The OBD 2 shows nothing (so I'm told) even thought the "check engine "lite goes on (stays on too). The plugs look ok although the shop put 2 new ones in. (damaged taking them out I think) The shop had it for almost a week and couldn't find anything. I also replaced the gas cap as that is supposed to create an EGR code. Nada. There doesn't seem to be any pressure in the tank but you can smell gas on opening the cap. When I replaced the filter it definetly sprayed gas all over. I know you are supposed take the cap off but I wanted to prove there was pressure in the tank. There was!! I have heard that the trans can cause this but the fluid is very clean and not burnt. It shifts just fine. It should for 2300 bucks. The van is gently driven (for a woman). It has 120k miles. This is the best I can do without prompting from y'all. Post question and I fill in anything else I can.
Additionally It has a slightly bumpy idle like and uneven cylinder compression. This comes and goes. I have been told that the TPI (throttle position indicator) is bad. ???? is it???
Thanks ahead for all the help. If this isn't the appropriate spot for this I'll put it where ever needed.
