Need one small steel wheel for an engine stand
5.6K views 13 replies 7 participants last post by  MrPhotographer06
#1 · (Edited)
I need one steel wheel for an engine stand that I am repairing and I need one rear steel wheel that is fixed to a solid axle. Any ideas for replacements or does someone have one they would sell? Or know of a manufacturer that sells replacement parts?
#3 ·
Yes, but i can't do that the way the stand is built. If I just welded 4 casters on the stand would be tipped forward. Here is a link of a stand that's identical.
http://www.toolsusa.com/asp/item_detail.asp?T1=PBE+RSC+7586&GENB=&UID=
You can see that the rear of the stand sits lower than the front. I contacted tools USA and they said there was no way to get replacement parts since all this mass produced crap is made overseas.
The only way I can see to do what you suggested is buy to small casters for the rear and two large casters for the front. But the rear is where most of the weight rests and small caster probably wouldn't support the weight :confused:
Just one wheel?
If you have access to a metal lathe, just turn one out of billet.
No access to billet? Make up a blank from something steel and close in OD. Fill in the center as necessary to fit the axle.
Concerned about appearances? Make two alike.
If you need an axle, use a Grade 8 bolt.
Don't forget Grainger, Carr, MSC, or.........eBay!
#8 ·
Grainger, had the wheels that I needed. Though it was tough to match the 1.5"x3" wheel with a 1/2" axle we found one set of wheels out of 1000 wheels that fit the size and load criteria. I bought 2 at $9 each and they are rated at 600 lb each wheel so the stand would fail before the wheel ever would.
On a different matter. I called around to serveral engine stand/hoist warehouses looking for replacement parts and couldn't believe what they told me. " Sir, all of our products are built over seas and no replacement parts are available since our products are made as throw aways". If it breaks discard it and buy another one :eek:
This country really is going on the fast track to hell.
#9 ·
You are probably right...........But, even if the thing was built here, what parts, other than the head, need "replacement parts"?
Get out some steel, and weld up your own....that's what hot rodders do. We make stuff ourselves............
"Kits"...."replacement parts"........old timers dont even think in those terms...........
OK.........rants over...........
#10 ·
An engine stand is such a simple outfit and so inexpensive I can understand why parts are not avaliable and in fact I would have been suprised if they were. I would think that about the only parts that would need replacing that could not be easily built would be the wheels (and how often would even these need replacing?) and as you found these are avaliable as off-shelf items.
#11 ·
haha i came up the right way..
the way my grandpa did..
you didnt have the tool you made it.. you didnt have the toy you made it..
you wanted something .. i earned the money or i made it...
the good thing to doing my VW with my grandpa is that he has alot of tools
that he made up to work on them with..
you know the little half end wrenches.. i dunno what they are called.. he
invented it 40 years ago because there wasnt enough room to get around
the whole bolt on VW's.. on his 1979 honda civic.. we couldt get the battery
without taking the selonid out and we had to make a wrench with a bench
grinder..
-Cam :pimp:
