Hello guys well I am getting a little worried here for next month for my cam swap. This is for a 350 small block chevy with a factory oem roller type setup. Ok guys I went through summit for a lunati custom grind and ordered a lunati 60110 hydraullic roller cam for my engine to be put on a billet core with the stepped nose along with the everwear gear.
I don't like the austempered cores being used as I feel a billet steel core is what should be used for any type of roller cam setup cause I have heard issues of the austempered cores going bad. I called Lunati to check to see if my cam was going to ship soon and they said they don't have that core on there shelf and they don't know when they are going to have some and the one guy said he will have to call me back. I am wanting to at least get my cam in hand by the end of the month so my question is would I be able to give the specs to say Isky or Comp Cam and they be able to give me the exact same cam specs and all?
The reason I am asking is because the voodoo cams use a asymmetrical lobe design and would Isky or Compcam be able to do that for me? I would like to go through Isky if I can. I have looked through there off the shelf cams from both comp and isky and I like the numbers of the lunati 60110 camshaft. Hope someone can help me with advice who have gotten custom made cams before. If you know anyone else besides them that could do this for me with a quick turnaround time please let me know.
Thanks guys
Eric
Thanks guys
Eric
