It's doable..
Malibu1347AD said:
so you are saying get the new pistons to w/in 10-12 grams of each other? Meaning one of my new forged pistons could way 10 grams more than one of my old hypers, as long as the finished product is all 8 of the new forged pistons being w/in a gram of each other if possible? And I can leave the rest of the bottom end alone as far as balancing? Thanks for the help guys, I'm pretty excited to get this build going.. :thumbup:
Well, ......... I would try to find a set of forged pistons to adjust my CR, which were no more than 10 or 15 grams heavier than your KB ceramics, and them lighten them as much as possible in the process of righting them to each other. You might be able to start out heavier than that if your wrist pins are on the heavy side, like 142 grams or so, because you can find lighter pins and you can also lighten those pins by tapering the inside of each end of the pin by a couple more grams. By the same token, you can get heavier pins if your new pistons are lighter...
You might also have the rods lightened a few grams while they are off. That's the quick and easy part of the balance, so that adjustment wouldn't cost much. Hope your rods are good enough for the power increase...
When it's all said and done, if you can be less than 10 grams heavier than you were, and all the rods/(pistons,
including pin weights with the pistons) as precision as possible to each other, then your harmonic should be about as good as it was before. The actual balance might even be better.... given that I shoot for a tenth of a gram top to top, bottom to bottom, and overall rod weight. Then I shoot for a tenth gram on overall piston weight.. Then I want the assembled weights that close if possible.
Most will say that being that close is not necessary, but it makes you feel really good about your engine and it can take hours more than shooting to a half gram...... But you could be watching TV all that time, or playing a board game.... I lose lots of time doing that kind of balance but I enjoy it more than TV.. I've think I've seen all the good movies at least once.
