Here's what I've found out over the years.
Carburetor = 190 - 195 degree thermostats
Fuel Injection = 160 - 180 degree thermostats
Carbuertors aren't as efficent at atomizing the fuel, so a warmer intake charge makes for a better mix, on carburated engines I usually run a 195 deg stat.
Fuel Injectors do a very good job @ atomizing the fuel, so you can run a colder stat, it usually helps to have a custom chip or custom programming to take advantage of running a 160 or 180 degree stat. But the colder the air the denser the air, so a well mixed cold dense charge will make more horsepower than a hot charge, so that's why Fuel Injected cars make good power running colder than a comprable Carburated car. Also most of the newer cars espically the OBDII ones will add more timing if it senses a colder intake charge, more timing usually equals more horsepower.
[ March 23, 2003: Message edited by: jamnut ]</p>
