I been having thoughts about different camshaft's in my engine, also have been reading my *** off, without getting nowhere !
The thing is I was hoping to get some recommendations regarding a good camshaft for my 350 Chevy engine. 4.000"x3.48" street/strip usage.
The block and crank is std unit. rods are aftermarket I-Beam with ARP bolts. Pistons are old Speed Pro forged flat tops, floating pin. 10.25:1 Compression
Heads are off the box 64cc Edelbrock Performer RPM 185cc, 2.02"/1.6" valves. 1.5 ratio rocker arm's
Intake manifold's a Holley Strip Dominator Single plane with 750 CFM Holley Double Pumper carburetor
I'we got 1.3/4" long tube headers with 3" collector into dual 3" exhaust with flowmaster mufflers
Current camshaft is some kind of comp cams nitrous cam. Hydraulic Flat Tappet. 12-568-4 113+5
Valve lift Gross - 507 / 525
Duration at .006 Tappet lift 284 / 305
Duration at 0.50 lift 240 / 253
Valve timing at 0.006 dur io 34 btdc /ic 70 abdc / eo 90 bbdc / ec 34 atbc
Lsa - 113, Ica 108
Lobe lift 3380 / 3500
RPM range 2800-6800
My question is. Would i gain some performance going to a tighter LSA ? some guidelines ? Since I have thought's about running this engine N/A only. I'm Also open for a switch to mechanical (solid) lifter camshaft, since this is Monza spends more time on the strip than on the street !
The engine is in a 2800 LBS H-body Chassis (MONZA) race reddy
TH-350 Transmission with 3500-3800 Stall converter.
Rear axle is GM 12 bolt with 4.11 gears and Spool. Tires are 28x12.5 Et streets.
Best regards.
Monzter.
Lsa - 113, Ica 108
RPM range 2800-6800
Best regards.
Monzter.
