Soooooooo aside from totaly regretting not just buying a posi rear end and putting it in.
Today I disassembled my rear end(GM 7.5 26 spline)to start my posi/gear install Ive been putting off. Got the ring gear torqued on the new carrier(Yukon posi)and carrier bearings pressed on.
I pressed off the old pinion head bearing and using 80grit duct taped to a drill bit in a drill press enlarged the centers to make test bearings(an hour long waste of time, shoulda bought a test bearing for $25 ugh).
Now I bent the factory pinion shim in the press when I pressed off the head bearing,so I made a new stack same thickness and installed the test bearings and old crush sleeve and put the pinion in and tightened it down till I felt no slop. Is that enough for test fitting or do I need to have proper rotational torque??
I ask because when trying to run a pattern I get a smuded unreadable result I dont trust.
Also when reading the pattern, according to Yukon I only need to be concerned with the patterns centering from the top of the tooth to the bottum (face flank) and that determines correct pinion depth.
So shimming the carrier is only to change the backlash reading on the dial indictor? Not the pattern?
Also the pinion races aint budging, we tried heating um punches etc... So Im just gonna slap the new bearings on the old races. Really dont have a choice doing this on the ground they aint coming out.
