i,m sure someone has morer smarts about valve to piston clearance. i need some help, and advice- when do i worry about clearance between the two. my new hyd. roller weighs in at .533/.548 lift 236/242 dur. i've installed the correct springs per specs. the heads are torqued down already and i would like to leave it that way (52.99gasket+soreback=sucks). 400 block with 5.565 rods
