mgold said:
Every State, and County work differently. It's annoying though that when you are trying to be responsible with used filters, there doesn't seem to be anyway to do that. I'll have to check around some more I guess.
First thing I would try, is calling your parts store and ask if they accept used filters. They WILL be obligated to accept used motor oil, I do believe.
This is from
HERE:
Federal Guidelines for Used Oil Filters
While most used oil filters were just thrown in the trash a short time ago, today we know they’re
recyclable. Some states have banned used oil filters from the landfill while others have placed
restrictions on how they can be discarded. The U.S. Environmental Protection Agency (EPA ) requires used oil filters be drained of all free-flowing oil before they are discarded or recycled. Most states follow federal requirements for used oil filter Disposal. Currently, U.S. manufactured oil filters
are exempt from hazardous waste regulation if the oil filter is:
• punctured through the dome end or anti-drain
back valve and hot-drained; or
• hot-drained and crushed; or
• hot-drained and dismantled; or
• hot-drained using an equivalent method to remove used oil.
What is hot-draining?
Hot-draining is defined as draining the oil filter at or near-engine operating temperature but above 60 degrees Fahrenheit.
In other words, remove the filter from the engine while it is still warm, then puncture or crush and drain the filter. The EPA recommends hot-draining for a minimum of 12 hours, although specific state requirements may vary. Most of the oil is removed from the filter during hot draining.
WARNING: Use caution when hot-draining filters to avoid being burned. Protective equipment such as safety glasses and gloves should be worn to prevent injury.
Finding Specific State Information
To find out the specific requirements for generators, collectors and processors for your state, call the
Used Filter Recycling Hotline at 1-800-99-FILTER (993-4583). The Used Filter Recycling Hotline is sponsored by the Filter Manufacturers Council and administered by the Motor and Equipment Manufacturers Association (MEMA) Environmental
Institute. Callers to the hotline receive an easy-to-read summary of their state’s filter management requirements; a list of companies in their area that transport, process and recycle used oil filters; and a brochure entitled “How to Choose a Filter
Management Service.”
