Generally speaking, raising the compression ratio will always increase power production. The law of diminishing returns applies to the application of compression, however. Jumping from a true 8.5:1 to 12.0:1 will net huge gains in torque and horsepower, but going from 12 to 13 will not realize as large of a return.
An engine's ability to fill the cylinder (volumetric efficiency) dictates to an extent of how high the compression should be for maximum horsepower. Notice that the huge mountain motors of nearly 600 cubes or more will generally run upwards to 16.0:1 compression ratio as even though they have huge cylinder heads, they still are not able to achieve a volumetric efficiency of let's say a top notch Winston Cup engine, which will only need 12.5:1 to get the job done. Of course, this is a generalization and many other factors will contribute to finalizing an engine's compression ratio. There are other terms such as dynamic compression , which is a term used describing real world cylinder pressures generated under operating comditions, and cranking compression, which is just as the name implies. Camshaft timing and compression go hand in hand and the proper camshaft should be used for a given compression ratio
This is something I posted quite some time ago, but it's very true. We all know that a 350 CI engine displaces 350 cubic inches of air if it operates at 100% volumetric efficiency, you can then burn x amount of fuel with x amount of air and produce x amount of power. If you increase the thermal efficiency of the engine, by changing the combustion chamber, increasing the compression ratio or adding thermal barrier coatings this can increase power production also.
What is the aim in running 11.0:1 compression ratio on pump fuel? If it's for maximum power, then surely you are also trying to maximize volumetric efficiency and then trying to maximize thermal efficiency, and then bam!!!!!!! you have exceeded the limits of pump stock unleaded fuels and preignition brings on detonation and you've smoked some pistons, your heads and your block!
Does anyone remember the Crower max fuel mileage system for the small block chevy? It utilized a special cam coupled with over 12.0:1 compression, maybe it was higer than that. Produced decent mileage, but no big power gains, much like a stocker or even less powerful. High compression does not equate big power.
If I put 11.0:1 in an engine, then it's going to be a good 11.0:1, but I would only do it to help save the bearings on maybe an endurance engine. If I were to use anything that requires racing type fuels, I'm gonna run 13.0:1 and higher and see some cranking compression of over 220 psi and the dynamic pressures will challenge even racing fuel. That's my point, if I run 11.0:1, I want to match my combination to deliver as much force to the piston as possible and regular unleaded fuel ain't gonna stay glued together under those conditions, if it is, then I ain't making the power I wanted.
