The number you want to look up for parts and rebuild kits is 17059207, which should be a 1979 Quadrajet used in a Chevrolet. The "1969" below it is not a manufacture date, so don't get confused.
This is a relatively new Quadrajet that should be a good start for your engine build-up. You need to first ensure the basic carburetor is working right, and then look at what performance tweaks you can make to get it working a little better for your application. Most of these Quadrajets will flow up to about 750 CFM, but as MouseFink mentioned, sometimes they were modified by GM to reduce flow in certain vehicle applications.
I suggest you buy the Cliff Ruggles book on Quadrajets and start reading through it. However, the book can get confusing because it covers all the Quadrajet models. For example, he may suggest an improvement for one carb model that does not even apply to your carburetor, so read carefully. You can also call his shop, or post to his online forum and he will tell you what rebuild kit to use, or what performance tweaks would make sense.
If that plunger is just an idle solenoid, it probably doesn't even need to be connected unless you have A/C.
Bruce
