Ok, so who out there is rocking some numerically low rear end gears. Not because they are factory and you are broke but wish you had 3.73’s or 4.10’s. I’m talking about you experienced guys that specifically chose 3.08, 3.15’s, 3.23’s and so on….
383 stroker here. All forged and internal balanced. 10.5:1 compression AFR 195 heads. 230/236@50 110lsa 550 lift 1.6 rockers Comp Cams xr282hr cam. Headers, Edelbrock performer rpm air gap, Holley 3310-2.
Plenty of timing. 18 initial, 36 all in at 3000. 14 vacuum.
TH350 with a 3000 stall
3.73 gears
My highway cruise is my last issue with this 72 Nova.
I have a whole post dedicated to my 3310-2 carb running rich at 3000 rpm’s on the highway at 70 mph. AFR’s are perfect at all other conditions. Idle, off idle, cruise.
I also have a whole post on my temps creeping up at sustained 3000 rpm cruise. All other driving conditions are perfect.
I don’t want a manual or overdrive auto or a gear vendor unit. Too expensive and I love this reverse manual valve body th350.
my only option is 3.08 gears. That will put me at 2500 at 70 mph with a clean 14:1 AFR.
I believe these carbs were never meant to cruise at 3000. Back in the day, the speed limit was 55 mph and overdrive came out.
3.08 gears will solve my issues on the highway.
also. I have no traction in 1st gear. It’s basically useless, so this may be a better deal.
many thoughts?
3.73 gears
many thoughts?
