Please help? I have done an exhaustive search trying to figure out what rear end I have, year, make and type of vehicle it came out of. I thought I would put the info out again, these are all the numbers I have found on/inside the rear end:
(1) 2 PY G 81452....Stamped, Located on axle tube
(2) 254333....Raised, Located on opposite axle tube
(3) Carrier # GM 12 410408N....Inside stamped
(4) Pinion # GM 25 1978.....Inside stamped
(5) Pinion # 3984832-12.....Inside stamped
(6) Ring # 398483121578....Inside stamped
(7) E168...Raised, located on pumpkin
So far with the above info, I THINK I have a GM 8.5 in, gear ratio 3.42 limited slip unit. Additionally I counted the teeth and the unit had the silver tag on the pumpkin to use limited slip oil. However, I would like to know the year and make to facilitate in getting the correct drums/brake rebuild parts. Any help or advice would be appreciated!!!! Thanks. Blaster :
