I have a SBC 350. Fairly built motor running about 12:1 compression and theoretically 450-500hp. I am having issues with the passenger side bank.
At idle the motor sounds great. No noise from anything. Once I hit about 2000rpm I start to get what I would call rocker clacking. It is always coming from the passenger side bank. I have re adjusted the rockers three times now. Even gone slightly tighter on this side just to try to find the noise. I've tried it with the valve cover off, with and without the stud girdle and still I get the same noise.
Comp roller rockers, high quality pushrods (I can't remember right now what they are. Push rod guides and everything. I have checked clearances and can't find anything rubbing or hitting.
What do I check next. I don't want to have to take off the intake and replace lifters but I wonder if I have one that is weaker than the rest. Would a weak rocker not make noise at idle but start as the rpm's increase?
Help Please.
I had wanted to take it out for it's maiden race tomorrow but that isn't looking good at this point at all.
Help Please.
