You need to have a lot of initial timing w/o going over the 36Âş or so of total advance.
A vacuum advance can work in you favor in this case- possibly. The 'possibly' is reliant upon the specs of the vacuum advance can. It needs to give you advance at whatever vacuum the engine makes at idle, in gear.
This will allow you to get "extra" advance from the vacuum can- this allows the idle to come up, which in turn allows you to close down the primary throttle blades to decrease the idle speed.
THIS, in turn, lessens the amount of transition slot exposure the carb has. That cleans up the idle and gives back idle mixture screw control of the idle- which may have been lost if the throttle blades were opened too far before using the vacuum advance.
From an earlier thread:
You should verify that what you are seeing at the damper and timing tab for TDC is actually TDC.
DETERMINING TDC will allow you to be sure the timing tab and damper are correctly indicating TDC.
MAKE A TIMING TAPE to see what the total timing is, w/o needing to use a dial back timing light. You can also buy a timing tape, they're not very expensive. The problem is if you have a different diameter damper than what the timing tape is made for.
Be sure the advance plate is free to move, w/o binding or friction.
HERE'S an exploded view of an HEI distributor.
THIS is a description of an HEI rebuild.
If you find the idle mixture screws have little or no effect on the idle, or in cases like yours where the idle speed in gear drops too much, I would recommend that you use the vacuum advance, hooked to manifold vacuum. It should be limited to around 10°-15° maximum of added advance. This is key to getting a good idle quality!
Using vacuum advance w/manifold vacuum will usually increase the idle speed- this then allows the primary throttle blades to be closed some, which in turn allows less exposure of the transition slot of the carb. That's desired because the carb will then be running on the idle circuit at idle w/o using too much of the transition slot to provide idle mixture. If the transition slot is over exposed, the idle can be erratic, rougher than it should be, overly rich, and there can be a flat spot transitioning from idle to main circuits.
You may well need an adjustable vacuum advance to get the advance at a low enough vacuum, given the lack of idle vacuum you now have. Using the vacuum advance should help bring up the idle vacuum as well.
If the vacuum advance you have
comes in OK but gives too much advance, you will need to physically limit the vacuum advance can's travel w/a vacuum advance limiter plate like the
Crane #99619-1,
#99619 Instructions. Or you can easily make one.
Crane has an adjustable vacuum advance can kit-
Crane #99600-1,
#99600-1 Instructions.
The
Accel #31035,
#31035 Instructions is an adjustable vacuum advance can for GM HEI that is said to allow infinite adjustment to both the amount and rate of advance. Comes w/instructions and tool.
You will need a vacuum gage to see when the existing vacuum advance starts, to see what the idle vacuum is now and how it changes when you use the vacuum advance hooked to manifold vacuum, and to see that the power valve is not opening at idle- this can create problems w/the idle quality as well.
This may seem like a lot of BS'ing around, but I truly believe it's the best way to get a good idle w/a crisp off idle transition. Without knowing the specs of the cam, there's no way to say for sure what the exact timing curve should be, but generally speaking, you want as much timing as early as it can be used- without causing detonation.
This could look something like:
• 18°-24° initial timing
• 12° mechanical advance
• 36° total timing
• timing all in by 2500 RPM
• vacuum advance adding 10°-15°
If the cam is VERY radical, you may even benefit from using a locked distributor, set to the total timing. But this is better reserved to cases where there is absolutely no way to use a curve.
