So I decided it was time to freshen up the top end on my 350. The motor is a '69 4 Bolt Main but it is in a '66 C-10 Stepside Truck. I put an Edelbrock Performer Air Gap Intake, Edelbrock Performer 600cfm Carb, MSD 6AL Ignition Box, MSD Pro Billet Distributor(w/vaccum advance), Taylor 8mm Spiro Pro Wires and NGK Platinum Plugs. I made the mistake of pulling the old distributor and wires without marking the rotor position; so after I installed everything I pulled the #1 plug and bumped the motor until my thumb was pushed off the hole. I then pulled the cap and noted which terminal it was pointing at and called that terminal #1 and procceded to run my wires accordingly. When I tried to fire it up I noticed that the carb was not squirting fuel. I pulled the fuel line at the carb inlet and bumped the motor and fuel squirted out fine, but i am not getting any fuel to the cylinders. After 15 minutes of cranking and choking and working the throttle I pulled the #1 and #2 plugs and both were bone dry. So here is were I need yalls help. First did I set my distributor and firing order correctly or do I need to pull the distributor and then set TDC and then re-install the distributor so it is pointing at the #1 cylinder and also does anyone have any ideas why the brand new carb wont squirt fuel? On a seperate note i converted from the old points distributor to the MSD Pro Billet and 6AL Box, I think I got everything hooked up correctly based on MSD's diagram but there was a Yellow wire with a prong connector that was hooked up to the old coil that I dont know what to do with. So does anyone know what that Yellow wire was for?
