Hey guys,
Been lurking here for two or three years and usually find what I need by searching....however, after slogging through 7+ pages of "low oil pressure" posts I havent found what Im looking for so I figured Id ask.
Question: Does a stock block SBC have a small welch plug that is fitted into the main oil galley under the rear main cap like the bow tie blocks?
Reason(s) I ask is that I recently rebuilt the 350 in my father in-laws 93 K1500 truck and now have low oil pressure when the temps come up to operating levels. The motor is bone stock other than being bored .030 and all bearing clearances in the rotating assembly were mic'ed (not plastigauged...mic'ed) and found to be perfect before assembly. New cam bearings were installed by the machine shop as well as hot tanking the block and installing the freeze plugs. Oil galley welch plugs behind the cam gear and the behind the flex plate were "staked" in place so I dont think any of those have flipped (least the ones behind the flex plate havent since its not puking oil out of the rear of the motor).
Cold idle with 10-30 oil was 60psi but as temps came up it dropps to 13psi at idle in gear which is lower than it should be in my experience on a fresh rebuild (less than 1 mile on this engine/cam break in time only). I pulled the oil pan and yanked the Melling 55 pump off and disassembled it and found a broken pressure relief spring (first time Ive ever seen that one) and debri from the spring had scored the pump rotors and body slightly. Since I had the pan off I swapped in a M55A pump since I had a few on the shelf which brought the cold idle pressure to 65psi and hot idle pressure to 18psi in gear which is still low from my experience. High RPM pressure (4000 in this case) oil pressure while hot is ~40psi which is about 20psi lower than I normally see with the M55A and there has never been any lifter bleed down/clatter with this engine other than a few ticks when its first fired which is kind of odd but it goes away immediately.
No debri in the oil other than the typical cam break in stuff that I normall see after dropping the oil out after breaking in a flat tappet cam. Oil has been changed twice since then with no bearing material/metal noted.
The one thing that worries me that I didnt think of until I had everything buttoned back up is that when I had the pan off I didnt pull the rear main to verify if the welch plug was installed by the machine shop in the main galley or if there is even one in there on stock block SBCs. I know there is a plug there on the bow tie blocks since thats what I usually mess with but didnt even think of it on a stock block.
Can anyone verify whether or not there is a welch plug under the rear main cap on a stock block SBC? Id normally look at one of the two or three orphaned SBCs that normally take up space in my garage but for once I dont have any orphans that arent installed in anything to look at LOL.
TIA
TIA
