Hi All! My son and I are rebuilding the 350 out of his 1987 R10. We just bought the truck and don't have much history on it so I’m not sure the engine needed rebuilding but its all apart now and we’re looking forward to the project. I’m looking for something moderate, decent torque but still a daily driver. It’s a 4-bolt block, mechanical fuel pump, flat tappet cam (I don’t plan to upgrade to a roller cam). Our budget’s not super tight but I don’t want to go crazy either. I do plan to take it to a local machine shop for cleaning, magna flux, bore/hone as needed, etc.
I wanted to get your take on the setup. The heads that are on it are the 3973487X heads, which I’ve read are decent except for the large cylinder heads. I don’t know much about them other than that but was thinking of having the machine shop take a look at them. Assuming they look ok, do you think they would work for a moderate build with a flat tappet cam like the Comp XE 256/268 advertised duration (212/218 at .050) with a dual plane intake and Holley 600cfm vacuum secondary? I would also plan roller tip rockers and to fill in the rest of the components to match.
With the heads, I was thinking that low compression would be one issue. I haven’t done that math yet but could I get to a reasonable enough compression (9.0+?) through choice of gasket, the pistons and deck work on the block or heads? I’m not opposed to new cylinder heads but wouldn’t mind saving some cash by reusing the existing heads (if it was a savings).
Thanks - Brad
Thanks - Brad
